Originally Posted by
Brian Good
I'm replacing one of the lower front a-arms and have a couple questions. First, installing the bearing that attaches to the bottom of the upright. I've tried drifting it in, but it doesn't look like that's going to work. Is this a heat-and-beat situation? A job for a hydraulic press? I'd appreciate any experience/suggestions.
Second, the reason I'm replacing the a-arm is that the hole where the outboard end of the pushrod attaches is fairly badly elongated, in a direction parallel to the pushrod. The bolt wasn't undersized or loose, so I'm wondering what else might have caused this. The other three corners are fine.
Thanks in advance for any advice.
