Hi guys!
I heard the engine run Friday!!! woohoo!!!
But...after I checked for leaks and shut it down, I moved to another project. About an hour or so later I checked the oil again, and I noticed about half of the oil (2qts) drained from the tank to (presumably) the engine.
Question 1....Why did it do that?
Question 2....Is that bad? I'm a little worried about blow by and having that much oil in the engine?
If it matters... Oil is routed from the bottom of the tank to the oil cooler...from the cooler to the filter...from the filter to the engine (pump)...then out of the engine (other side of the pump) back to the top of the tank.....
Any ideas?
