Peter;
747-100: 5,500 ft² (510.95 m²) = 181.8 lbs/ft²
747-400: 5,650 ft² (524.90 m²) = 177.0 lbs/ft²
Throw on a craphouse full of flaps, and these numbers take a plunge. Look at the lift formula.
Lift = (1/2)(coefficient of lift)(wing surface area)(air density)(velocity²)
Although there is but one lift formula to handle both symmentrical and asymmetrical wing designs, on any given day with these two designs of identical SA and tested in identical air densities (slugs/ft^3), lift really comes down to the CL (inherent wing design) and V² (THIS IS IT!!).
Think of it this way: a 1 degree angle of attack on a symmetrical RW will most certainly produce LESS lift than a 1 degree angle of attack on an asymmetrical wing of pronounced camber.
