Page 4 of 4 FirstFirst 1234
Results 121 to 124 of 124
  1. #121
    Senior Member joshuagore's Avatar
    Volo/Round Lake
    I don't think anyone in council will protest, but next time the block is torn down, I will clean it off. From the sounds of it, it holds heat in anyways
    How do you guys protect against rusting?
    Josh
  2. #122
    Plainfield, IL
    Liked: 190
    Josh,
    Bruce is spot on, no paint. At the same time, you are correct as well. The guys in MC may point out that the paint must go, but they will not turn down an entry.
    As for any engine corrosion issues, don't worry. Once you start running the engine at speed for 30 minutes at a shot, the engine will provide itself with corrosion protection
    Bill Bonow
  3. #123
    sacramento, ca
    Liked: 72
    the paint rule was to make sure no one hid anything under the paint or applied something expensive to reduce heat. Many years ago there was a motorcycle engine paint that was supposed to reduce heat. If any engine is going to be stored, especially in a moist winter, spray the entire case with WD-40.
  4. #124
    Senior Member LanceKTM950's Avatar
    NE Nevada, USA
    Hey Josh!
    GREAT write-up doing something most of us will only dream about, or never have time or guts to do.
    When are you running again? Anytime you run a Council event let me know and I'll run over to intro myself and help with whatever I can.
    Lance Renshaw
