Results 1 to 5 of 5
Thread: Front sway bar
    Cleveland, OH
    Liked: 111
    Default Front sway bar
    CLUB RACING TECHNICAL BULLETIN
    DATE:
    January 20, 2010
    2. #543 (Erik Skirmants) Alternate sway bar
    In 9.1.1.J.8.f, add: Optional Front Sway Bar: Rotating blade style with or without cockpit adjustment. Minimum blade thickness 0.155” ±.005” Main Shaft diameter 0.590” ±.005”, Length 6.006” ±.010”. Cockpit adjustable full bar kit PN:
    WM1121008. Bar kit only (with set screw lock) PN: WM1121007”
    Parker, Colorado
    Sincerely,
    Erik Skirmants
    SCCA Enterprises
    Senior Member Bruce Allen FSCCA #82's Avatar
    New Hampshire
    Default Front bar-How adjustable?
    Erik,
    Will the bars allow adjustment softer than the current bar at full soft?
    Bruce, the "Greased Shadow"
    Parker, Colorado
    At full stiff the new bar will be the equivalent of the old bar at "1/2" in" and at full soft the blade is 50% softer than the old bar all the way out.
    Sincerely,
    Erik Skirmants
    SCCA Enterprises
    Contributing Member Eric Cruz's Avatar
    Barhamsville, VA
    Liked: 59
    Cool beans. Thanks, Erik!! I have contacted my CSR. If they have thawed out in Florida yet I might even receive it soon...
    Best regards,
    Eric
    If you don't think too good, don't think too much.
    - Ted Williams
