    Liked: 157
    Default Throttle cables preferences
    Anyone have strong opinions on this? I see two options. a) Push-Pull cable and some kind of modified lever at the throttle body or b)motorcylce style pull cable using the original Suzuki interface at the throttle body
    If option b) is there a source for very long pull cables?
    Cheers
    atlanta, ga
    Liked: 136
    Default I used
    the stock suzook throttle body mntd cable holder, and drilled out the "ball end" holder on the rotating bit just a scosh to fit my tandem bicycle rear brake cable, which comes with the ball on one end and bare at the other.
    Not at all:
    a) flashy
    b) very robust looking
    c) heavy
    d) to be found on a purpose built car
    e) expensive
    BUT:
    a) has worked wonderfully for me since day one
    b) evidently is robust enough
    c) very light weight
    d) cost about $6 fiddy
    I have seen some cables made out of -3 s/s brake/clutch line, w/ cable run thru the nylon lined inner, and cable ends made onto the -3.
    I also modded the stock VD/Pinto throttle cable to have as a spare...
    Coop
    Liked: 157
    Default That the ticket!
    Tandem bike brake cable. Outstanding idea. And as you point out, wieghs nothing and costs about what I spend on lunch each day. Bamm!
