Bob,
There is no company line with me. If you are alluding to the fact that because I run a Citation and it is equpped with the ICP calipers I am doing their bidding you are mistaken. I do not do anyone's bidding unless they are a paying client and the last time I reviewed my checkbook I was paying, not ICP or Citation Engineering.
A vote was taken and the proposal was not moved forward at the Advisory Committee level because there are two sources for ferrous calipers. This fact was confirmed by Chariman David Arken. In this regard the following information was circulated to the Committee:
--- On Thu, 6/18/09, Kevin McDonnell <kevin.mcdonnell@apracing.co.uk> wrote:
From: Kevin McDonnell <kevin.mcdonnell@apracing.co.uk>
Subject: RE: AP Racing - Contact Form
To:
arkend@sbcglobal.net
Date: Thursday, June 18, 2009, 12:04 AM
David,
Yes, we do still make the cast iron calipers, I have attached the details
above for both versions that are still available.
Best Regards
Kevin McDonnell
Rally Engineer
Tel: +44 (0)24 76883315
Fax: +44 (0)24 76639559
Mob: +44 7785 222761
As noted in an earlier post, the aluminum caliper was recommended by the committee for S2 since there is no ferrous caliper available in that particular size/configuration. (LD65??)
Bob, it is certainly your series and if you want aluminum calipers thus it shall be. I think the series is great and I am not taking a stab at you or Mike and your managment thereof, just pointing out my differing opinion on this issue. I simply disagree with departure from Club rules when in my eyes there is not a good solid reason behind it. This rule is simply one reason for racers not to play in both camps. There is not a great deal of cross over so perhaps it is not a major issue, but departing from Club rules was in my opinion where Baytos got in trouble.
As you correctly point out, these calipers are not mandatory however if nothing else they will be a perceived necessity and will be an expense for most every existing car in the series. At this time I can probably afford to purchase a set of aluminum calipers to run if I so desire and believe them to be an advantage; how will others react? Are they ready to spend the necessary $1200 for the upgrade?
Time will certainly tell and it is a step forward albeit a slippery slope.
Cheers,
John LaRue
