Thread: 008 running hot
    Senior Member aspenripper's Avatar
    pp
    Default 008 running hot
    Looking for some help regarding 008 cooling issues in high air temps
    Ran at summit point , grid ambient temp was 90+degrees with 66% humidity and sunny friggin hot.
    Warmed car on grid to 160-170 and went out ran maybe 3-4 laps warning lamp on, cooled maybe 10-15 on straight but would not stay down, so I brought it in.
    I see in old posts that there was some kind of 008 update for a overheating issue ? anyone know what that was ?
    I had no boil over at all as I brought it in when that lamps came on
    Any input appreciated, and I already checked off a new rad cap
    ed
    "The visibility at the best of times is liable to be a bit hazy due to clouds of ignorance"... Carroll Smith
    maryland
    Default summit
    what temp did it reach?
    Fremont, NH
    Default Warning temperature
    Also, what temperature is your alarm set at?
    With a reasonable radiator cap, 230 deg. should be safe for water. You can set the oil alarm for around 240-250.
