Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Global Moderator DB4 Tim's Avatar
    NM
    Liked: 24
    Quote Originally Posted by RoadHazard View Post
    So does that mean you enjoy onanism?
    Look it up: http://dictionary.reference.com/browse/onanism
    ...O_MY.....
  2. #42
    Wetmore, CO
    Liked: 109
    Default Update on exhaust
    Well, I added a second muffler and tested routing the exhaust out a piece of conduit. No change in volume. I believe it was stated somewhere that the exaust isnt the loud part for some generators. Verfied!!!!
    Corky!
  3. #43
    Liked: 1488
    Most of that noise comes from the cooling fins transmitting all the mechanical clank inside the motor. The little hondas, yamahas, and Kipors put a lot of ducting and insulation along the way to knock that down. It also helps that a dc generator driving an inverter only has to run at an RPM to handle the load, instead of something like 1800 or 3600 RPM like a synchronous gennie has to turn.
  4. #44
    NM
    Liked: 24
    Got pictures....or the where did you get the big-o-cups
    Quote Originally Posted by bill View Post
    I also use the centuri generator exhaust, I use large rubber suction cups to attach the rubber bracket to the side of RV, takes the pressure off the exhaust just fine
  5. #45
    Lodi, CA
    Check Harbor Freight... search suction.
    Charles
