    Contributing Member Shep's Avatar
    Rochester, NY
    Default Titan Steering Rack Disassembly?
    Hi folks,
    Did a search, and didn't find a clear answer to my question...
    When disassembling a Titan-style steering rack down to its component pieces, in which direction should the pinion gear be pressed out? Toward the backlash adjusting ring ("front" in my case), or toward the steeting column linkage ("rear"). The folks at Pegasus were good enough to supply me with the adjustment instructions, but it doesn't cover the removal of the rack and pinion.
    Just wanted to do the pre-season prep, and didn't want to break anything in the process, lol.
    Erik
    I would say to take the ring off and push it out that direction.
    No press should be needed other than a strong finger. Do not force it under any circumstances.
    Great Falls, VA
    Default Titan manual?
    Where did you get the drawing? Is there a Titan assembly manual somewhere?
    Larry Oliver
    International Racing Products
    Titan Mk 6B owner
    Larry Oliver
    Sequim, WA (USA)
    Liked: 34
    Default Titan steering rack parts list...
    I knew I posted this in the wrong thread!
    Attached Files Attached Files
    Tiga FFA-77 s/n 38
    fred short motor racing
    "Turning money into noise for over 2/100 of a century"
