    Member Joby Graham's Avatar
    northern N.J.
    Default Swift Body Mounting Tabs
    Does anyone know of a source for the body mounting tabs that mount on the shear plate on DB-1, 2 (I think) and 3s? I'm referring to the "L"-shaped aluminum brackets to which a Dzus spring or camloc receptacle is riveted. Ray at Protech no longer makes them. I know that they'd be easy enough to make, but time is at a premium and it would be easier for me to buy them, if possible.
    Joby Graham
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Joby:
    Are you talking about the rear shear plate, and the recepticle that holds the rear of the engine bay panels on?
    Bob
    PORT ST LUCIE , FLA
    Default plates
    Alan Oppel @ Pit Lane Services just redid the body on a Swift FC car. He may have some extras as he usually makes a couple more of special pieces than he needs . He is on the board. Good luck
    Member kevin keller's Avatar
    NJ USA
    Joby,
    Check with Neal Porter, Neal@porterracing.com . He can help you.
    Kevin
