From another thread:
I've managed to get both my 6'3" 200# frame (50+ lean build other then a bit arountd the waist) along with that of my 6'4" 200# son (20yr basketball player) fitted to the car. What I've done:
Move peddles to a rear mount on the peddle box (may not be factory holes), shortened the brake rods from 3.3" to 2.8" and removed existing spacers. Clutch & throttle cables are at max length. Pretty much maxed out here. I can rest by heals on the rear edge of the peddle box, my son can't (too many basketball injuries to his ankles!)
Removed seat, fit "fighter pilot" pad on belly pan, fuel cell cover along with a bit of backpackers foam to adjust fit and support upper back.and rear firewall. Not bad, tight fit on the width... head is about half way in the roll bar hoop.
Have just over 2" from helmet to roll bar, clear streight edge resting on front hoop and roll bar.
Have 3~4 fingers between knee's and cross brace under dash. Plan on leaving for the time being but remove later. Steer shaft rest on top of it, move it above an gain a few inches... unless others have a better idea. Legs are low enough that shifter clearance is not a problem.
Shoulders are even to or just above the cross brace inside the roll bar, can just fit a 1" foam headrest on the existing headrest mount (cut even forward of the brace).
So... mounting shoulder belts to the cross brace inside the roll hoop is an option, after mounting tabs and reinforcing.
But... I don't want to reinvent the "wheel", if others have solutions I'd like to hear about them. My goal at this time is to make the car so I fit, it's safe and relable with min modifications. Then I can drive, tinker, modify as needed. I am a proficiant welder (TIG / MIG mostly) and fair fabricator, I also have access to both at work (I'm in heavy equipment parts).
