CAD ideas for fitting the engine. Plan as of now is to gut an LD200 (have a trashed one), make a chain driver version of it, then reuse all the spuspension pickups etc. The oil tank/bell housing will be replaced with a small steel weldment. Headers might have to go through one more revision to clear oil pan. On the back end of the LD200 the bearing carrier interface will be used for the start of a crush box which has to pick up the three bolts (floating in space here) for the rear wing and sway bar
Comments???
