Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
  1. #41
    Muncie, Indiana
    Liked: 984
    Thanks for the clarification. John
  2. #42
    Not knowing any better, but will revving the Ztec to the higher RPMS adversely affect engine life, which is the big selling point in the first place.
    Does anyone know for sure just how much a top Ztec and a top Pinto from Sandy cost?
    I ask cause I heard some seemingly very high numbers this past weekend.
  3. #43
    Senior Member Camadella's Avatar
    Ithaca, NY
    A Zetec, complete with all of the bits necessary to run (like the intake manifold, wiring, clutch, sensors, and the like) costs in the neighborhood of $11K. Not bad, considering that they go for a long time with no attention.
    I can't really speak for the Pinto - but over the course of a season, the Pinto is likely more expensive if you run the same number of laps.
    What you really want to know is the cost per horsepower per mile - what we engineers refer to as "mile specific dollar consumption", or MSDC. I think that virtually everyone will agree that although the Zetec has a somewhat high initiation cost, it has a much lower MSDC once you've taken the plunge. Kind of like the Fram man - you can pay me now, or you can pay me later.
  4. #44
    Fremont California
    Default Zetec RPM's
    Steve,I shift at 7300 with 193HP and a STOCK Zetec bottom end. I have 3000+ miles on the engine and it still makes top HP and has the same Oil Pressure as new. With the restricted Zetec MAP I doubt you could hurt one.
  5. #45
    Default in ballpark, or in parking lot?
    Just a guess, and only a guess, based on some three year old prices.
    If you walk in and buy a race ready sealed zetec, and everything needed to convert the chassis (e.g. wiring, ecu, headers, fuel pump, drysump system, clutch, bodywork, etc.) , with no core... look beyond $17K. (per Jay Novak )
    I'm guessing if you want a national level pinto, and you don't carry a core in with you, I bet you are looking at for a Al head pinto... $12K - $14K.
    If you have a running iron pinto as core, and want it built top shelf with an Al head, I'm guessing $9K, without headers.
    Refreshing a top shelf iron pinto for the Runoffs... $4K - $6K.
    I'm talking an engine that has serious dyno work, with all the tricks matching the carb to the intake, and optimizing each cylinder to match.
    Your mileage may vary.
    Last edited by Purple Frog; 08.12.08 at 9:42 AM. Reason: J is more knowledgable than i
  6. #46
    Muncie, Indiana
    Liked: 984
    Steve,
    If I recall correctly the guys who originally ran the Zetec in the pro series without a restrictor also achieved good life from the engines. I have no idea where they were spinning them, perhaps one of them could chime in and comment.
    John
  7. #47
    Columbia, SC
    Liked: 201
    Steve,
    John
    6500-6700. Put 5000 miles on the engine in the first year with no problems other than clogged fuel injectors at one of the Mid Ohio rounds and nothing wrong before or after that for 2 years.
  8. #48
    Default Exact Zetec engine costs
    As there seems to be some interest, I thought that I would post our total eaxct Zetec engine costs as purchased this spring.
    Zetec F2000 engine complete - $11,500.00
    Chassis Harness - $1,445.00
    Pectel T2 ECU - $1,270.00
    Air scoop complete - $585.00
    Shipping - $260.00
    Walbro fuel pump - $137.00
    HiTech stainless headers - $1600.00
    Starter motor - $325.00
    Total engine costs - $17122.00
    Now this does not include a car chassis harness, coolant plumbing, oil system plumbing, oil cooler, and other misc bits associated with the engine installation, which probably added another $1000+ to the bill.
    Note the edit to change engine harness to chassis harness. The engine harness is included with the Zetec engine.
  9. #49
    Ithaca, NY
    Default Additional bits
    Additional bits not mentioned include:
    Alternator (I forget, somwhere around $200)
    Alternator mounting bits (Somewhere from $200-300, depending on which setup you get)
    Rear bodywork (i.e., engine cover) The Pennon one is very nice.
    Bigger battery (probably necessary as ballast)
    YMMV, of course
  10. #50
    Senior Member anthonywill3's Avatar
    Lower Slower Delaware
    why is a Zetec complete engine so expensive ($11,500)? The GCR states "[SIZE=1]
    The philosophy of the Zetec engine in FC is to allow limited engine rebuilds but no performance modifications to the engine. Blue printing, balancing, head porting, polishing, etc. are strictly prohibited and against the spirit of the Zetec formula" , [SIZE=1]
    "All surfaces on the head, block, rods, pistons, and crankshaft must remain as manufactured by Ford and may not be altered in any way. The original casting marks and cast surfaces must remain as-cast and also meet all of the Ford design values and tolerances as stated in the Ford factory manual or as delineated in these specifications. The block may not be decked.", so where is all the cost coming from? Not to mention that the $11,500 doesn include the ECU, airbox, etc. Someone please edumacate me!
    [/SIZE][/SIZE]
  11. #51
    St Petersburg, Florida
    Liked: 31
    There is a profit?
  12. #52
    Default Zetec engine
    Remember that the Zetec race engine is MUCH different than the Ford Zetec engine. The fuel injection system, dry sump system, ignition system, harness etc are all part of the price.
  13. #53
    Senior Member BrianT1's Avatar
    St. Charles, Illinois
    Liked: 179
    What is the cost of a rebuild for the zetec motor??
    Contributing Member Ron B.'s Avatar
    Minneapolis, MN
    Liked: 6
    Default Rebuilid cost - Zetec
    After aproximately 11K milies I paid $4K for a fresh motor. Ready for another 11K miles.
    I think Church had one with even more miles than that......
    Ron
  15. #55
    Minneapolis, MN
    Liked: 6
    Quote Originally Posted by buudrow1 View Post
    There is a profit?
    Holy crap - Jon is alive!
    Ron
  16. #56
    Correct, thats why I am trying to get the full breakdown as to how the motor costs 11.5k, plus the harness, ecu, etc.
    Yes Jon, of course you should make a profit!
    Just trying to understand how it breaks down...
  17. #57
    Lula GA
    Default Zetec kit
    Is there enough interest for me to assemble a install kit for the zetec engine in a pinto car for sale??
  18. #58
    Ridgecrest, Ca
    Liked: 259
    as the owner of several 2-liter Pinto engines I've found this year's early start to
    performance creep and whining season amusing. while the arguements this
    year are smoother, it's still my sense they're wide of the apex/mark! while
    I may have missed it, Zetec flywheel weight (rotational inertia) needs to be
    included in any objective arguement for more useable area under the Zetec
    horsepower vs rpm curve! lighter Pinto flywheels is not the answer, only an
    all but certain invitation to more bent valves and ruined heads. as forecast
    before the experiment, the only test of a lightweight Pinto flywheel by an
    expereinced driver I'm aware of resulted in tweaked valves and a "soft"
    engine in less than a weekend! to the best of my knowledge Zetec parity
    with 2-liter Pintos is the Club's stated objective, NOT 2-liter Pinto parity with
    Zetecs, and Not unrestricted Zetec parity with with 1-liter stock motorcycle
    powered cars.............
    rather than this seemingly endless whining about Zetec parity in Club racing, wouldn't
    it be refreshing if a member put their name on a specific objectively verifiable change
    to the GCR as currently written and submitted it to the Club for consideration
    using the Club's defined process. if someone has actually done the work, a change
    proposal is approaching brain dead simple:
    1.) name of the member proposing the change that is prepared to speak on the
    merits of the change (fronting a change for someone else should be uncomfortable
    in my view)
    2.) current rule as written
    3.) proposed rewrite of the exisiting rule or remove and replace wording
    4.) objective of the change
    5.) members effected/potentially effected by the change
    6.) alternatives considered in lieu of the proposed change
    7.) reason(s) each of the alternative considered are not being recommended
    (preferably with objectively verifiable data to support conclusion(s))
    8.) objectively verifiable data that supports the merits of the change
    (the perenial rub, apparantly all sole source suppliers, most suppliers, and too
    many members would rather deal in the domain of hearsay or "they" told me
    these are the numbers)
    9.) adverse consequences of approving the recommended change; there is
    risk associated with all change.
    given the Club's track record of translating whining into objectively verifiable rules,
    particularly where sole source suppliers are involved, why does anyone want to
    continue with the whining approach? if 2008 continues at the current rate of
    sole source messes, the Club will almost certainly have a fully qualified
    "clean-up" team by year's end. looking on the brighter side, a team with well
    honed skills might represent a new revenue source for the Club addressing the
    parade market that welcomes life stock........................................
    Art
    artesmith@earthlink.net
  19. #59
    Liked: 179
    Robert,
    I would say yes.
    Brian Tomasi
  20. #60
    Virginia
    Liked: 9
    Quote Originally Posted by RWalden View Post
    Robert,
    I believe a cost effective, all inclusive zetec conversion package from the manufacturer would be well received by the owners of 1998 and newer pinto VD's. Perhaps a retro kit for 94-97 cars could come later if the newer kit is successful.
