Shocks are a used pair of koni steel body 8211 hydraulic shocks. Extended length is 11.125", travel is 1.875". If the bump stops are removed, about 1" of additional travel is available. These were shortened and rebuilt with B2 valving installed by koni. They could probably use a rebuild, or be used as is. 225$ or offer for the pair. Spring perches included.
The tops are steel, and if you wanted a longer extended length (and are ok with the existing travel) they could be cut and an extension welded in to achieve whatever length you needed.
