Stan-
unless I've missed some changes to the GCR, my read of the rules as currently written permit intelligent conditioning boxes for input to the stock ECU. mapping a stock ECU wouldn't be that hard; a good digital scope, a half dozen voltage dividers, a signal generator or two, and some very structured patience. not that many years ago you could get a disasembler for just about anything in the valley although that wouldn't be needed for the envisioned control system. the algorithms in the stock ECU would have to simplely be given the inputs to get the "right" answer; A x B equals C, the answer. 15,000rpm is unbelieveably slow in the digital domain so the computing timeline would be a piece of cake.................. hardest part of the project would be isolation of the digital computing section from the A/D's and D/A's; in the end it always works out that way
you are right thou, it would be a lot easier and not nearly as constrained in a world where use of the stock ECU wasn't required for compliance[/FONT
Art
artesmith@earthlink.net
H.4. Engines
A. Motorcycle-based 4-cycle up to 1000cc.
B. Engine internals and compression ratio must remain stock. The
competitor must present, on demand, an original factory manual
for the engine to allow compliance verification
C. The stock ECU shall be used. The ECU fuel map may be changed
Devices that modify inputs to the ECU (e.g., Power Commander)
may be used. Stand-alone after market ECUs are not permitted
