Question maybe some of you more experienced racers wouldn't mind answering.
When you weigh your car how do you deal with the variable weights such as fuel or other?
Do you weigh in at some minimum fuel load so that when you are done racing it is unlikely that you will come in with less fuel and thereby be above min weight? How close to the minimum of 1100 lbs do you push it given the uncertainty of your raceday weight vs garage setup day weight. I will be using Intercomp digital scales so accuracy is decent.
Chris
