Results 1 to 9 of 9
    Las Cruces, New Mexico
    Default What oil do you use in the Suzuki GSXR
    Ok......another question:
    Just drained oil for the first time out of engine used one day at PIR.........
    What brand oil do you use in the Suzuki GSXR 1000 and what weight?
    Motul? Mobil 1? Redline? Amsoil?
    Weight?
    Richard Dziak
    email: sonewmexico@gmail.com
    Marietta,Ga.
    Liked: 61
    I've been using Motul 5100 synthetic blend 15W50 in my Suzuki Hayabusa 1300 drysumped engine for 2 yrs now with good results. $32.00/gal @ the local mc shop.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    Atlanta, Ga
    I use Motorex
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    2004 Mygale SJ04 Zetec
    I did some Googling a month or so ago and found a few comparison articles. IIRC, Amsoil did the best. However, I went with FormulaSuper's advice because Amsoil is pricey and not easy to find. As you probably already know, don't use automotive oil because our engines/trans/clutches need different characteristics.
    Atlanta, Ga
    Since George shared this, I guess I will also:
    http://p081.ezboard.com/fdsrforumfrm...icID=571.topic
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    I went for the Amsoil 10 w 40........
    With the George Dean wet sump on the Suzuki GSXR it took 4 1/2 quarts, which included a new Fram PH6018 filter.
    Richard Dziak
    San Jose, Ca
    Liked: 92
    Default 1 vote for redline
    I've used redline 40wt racing in both the old and new kawi zx10r motors. No problems with clutches, etc. Its good to 300 degrees with no water circulating too.
    tyrone, pa
    Just make sure you use a motorcycle rated oil. If you use an "automotive" oil, your clutches witl start to slip. Redline has a motorcycle oil, that is supposed to be real good, don't know the price though. Repsol has a good full synthetic oil the about $5 a liter.
    new york
    Default red line
    red line makes a good oil.
