This weekend was the first regional race of the year for us here in AZ. The race followed a double school so many of the drivers were racing for the first time. I believe there were only 10 cars entered in the wings and things group. 2-FA, 2-FC, 2-FB, 1-FM, 3-FF.
So.....I'm going to do this for "marketing" purposes....but please know it is done tongue in cheek....
Phoenix F1K.07 sets new track record and dominates FB field at PIR!!!! Richard Dziak piloted his beautiful red Phoenix to victory in his first time at the 1.5 mile Phoenix International Raceway infield course, establishing a new track record along the way.
Alright....now, as Paul Harvey says....for the Rest of the Story....
Many of you know that I had a pretty bad crash in my DSR at PIR in early 2006. A brake failure going into T1 (at about 130 mph) caused me to hit another car and to be launched through the air and impact the T1-T2 SAFER barrier at 117 mph. I was pinned in the car for 30 minutes and suffered multiple fractures of my right leg. With that as my last memory of PIR, I began the weekend....with a flock of butterflies in my stomach as my co-pilot.
The weekend promised to be extremely hot and lived up to the promise. The school sessions (I was instructing some new open-wheel drivers) were brutal on Friday and Saturday as temperatures were hovering in the 107 degree range. Sunday (race day) dawned a few degrees cooler than the previous days, but early cloudcover burned off pretty rapidly and temeratures rose quickly above the century mark again. I saw 105 degrees on our tow vehicle dash readout.
The day started with an early morning 15 minute practice and my goal of merely having a positive session to rid some of my demons to begin the day. We began on the same tires we ran for both races at Sears Point a few weeks ago. I was tip-toeing through T1 and the oval as I began the session and slowly started to pick up the pace. I never did get to being flat-out through T1, but did start to roll the car through the oval much better. I managed to do a 1:02.6, which I thought was very good based on how timid I was out there. The car had a slight push in the slow stuff....which is what we expected.
The second session came quickly as the region combined two groups and caught us off guard. I managed to roll to the grid as the other cars were completing their first lap. We ran the same set of Goodyear 250's and made a small front ARB adjustment to try to dial out the slight push from earlier. My goal was to get flat through the oval and to work my way up to holding the throttle through the transition off the oval into T1. The car felt really good and I managed a 1:01.2 and still had left a bunch on the table for qualifying later. The car still had a slight push.
For the qualifying session we put on some stickers (Goodyear 250's) and again made a slight front bar adjustment. My goal was to get solidly into the 1:00 range and then pull off as we didn't want to fry the tires. I patiently made my way around for a few laps as I was trying to find a nice big open space on the track and let the tires come slowly up to temp. About halfway through the session I started to get on it and began to catch a slower Pro Mazda car. He had really good power, but I was eating him up in the corners (I'm sure it was his first time at PIR). I knew if I could get by him I would have a wide open track so I started to push....until something went boom on lap 8. Smoke trailing everywhere and I smelled burnt oil....not good. I managed to qualify 3rd overall with a 1:01.5 on lap 7, but our day was done. The top qualifyer was a Swift 014 at a 59.8.
After we did a buttload of oil dry in the hot pits for all the spewed Redline 40wt, we started to evaluate the damage to the GSX-R1000 motor and found a rod laying on the duffuser as we removed the engine cover. The odd thing was that the rod was complete (a bit bent, but complete) and had zero discoloration. The rod bolts were both broke off in the rod. We started digging some more and found the rod cap (again complete) and the bearing material....none of which showed any signs of excessive heat. We also found a very large hole in the case and dozens of pieces from the bottom of the piston and the complete wrist pin with nary a scratch on it. Pulling the data from the AIM dash showed good oil pressure all the way through the session, and all other temps, etc. in an acceptable range, though a bit high due to to the ambient temp. The logger showed a cockpit temp of 110 degrees. We're pretty certain this engine failure was caused by a part failure and not from the result of oiling issues.
I'm pretty bummed because the car was performing very well. The fastest I had ever run in my FC (after 3 years of driving it) was a 1:01.9 so I can't wait to get back out there. I guess this may be the opportunity to install the new 2007 engine...
Richard Dziak ran a good safe race and got the finish he needed. His lap times are not near where we are with the prototype, but his goals and aspirations for racing are different than ours. This was the first outing for him in his car and he said the car performed flawlessly and he was very surprised at the performance of the engine. Congrats to him on the win...I'm sure he'll post some of his thoughts once he gets a chance.
Matt Conrad
Phoenix Race Works, LLC
