I have in mind a certain oil cooler arrangement, but it doesn't seem to be common.
I'd like an oil cooler that is very similar to the layout of my Van Diemen water radiator. Ideally I'd like it to be about 7" tall. The length isn't critical (12"-20"). I'd like -8AN fittings.
More info: I'm plumbing it after the scavenge pump and before the oil tank. Since it will be a mixture of oil and air, it's important that I exit the oil cooler from the bottom. Otherwise, (if I exited the top), there may be oil sitting in the bottom of the cooler that never circulates.
While Googling for the cooler I want, I came across lots of coolers that would be great, except they are single-tube, multiple pass coolers. I've never seen that type plumbed into the oil system on a high quality race car. However, I'm wondering if it might be okay for my application (since it is low pressure, feeding into the oil tank). The type of cooler I'm referring to is usually used for automatic transmission coolers, like the attached picture. Bad idea? It would solve the problem of "puddling" oil never exiting the oil cooler.
Thanks for your thoughts.
