Phoenix Race Cars, Inc. announces a "Crate Engine Program" for Suzuki GSX-R1000 engines specifically built for SCCA F1000 competition rules. This program provides "on the shelf" engines ready to be shipped within 48 hours of ordering and fast, economical shipping to most major US markets.
The two packages currently being offered are as follows:
2003-04 Based Engine Core (989cc)
Complete tear-down and inspection
Complete re-build with new bearings, seals, gaskets, etc.
New Billet Clutch Basket, Heavy Duty Clutch Springs
Re-Mapping of ECU
Tuned and Broken in on the Superflow Dyno (Dyno sheet provided)
Approximately 160 Rear Wheel Horsepower*
$4,995 (Includes $2,000 Refundable Core Charge)
2005-06 Based Engine Core (999cc)
Same as the 2003-04 Model except:
Larger (1mm) Titanium Valves
Improved Cam Timing
Higher Compression
Dual Injector Set-Up
Improved Electronics
Approximately 165 Rear Wheel Horsepower*
$5,995 (Includes $3,000 Refundable Core Charge)
All engines are built by George Dean's Racing Engines.
* These numbers are using a stock exhaust system and stock airbox. When comparing horsepower...please ask the supplier to provide you a Rear Wheel Horsepower number. Several other entities are advertising 175-180 HP numbers, but those are NOT Rear Wheel Horsepower numbers, but a theoretical number at the crankshaft.
We also offer:
Oil Fitting Adaptors (-8 AN) $50/set
Complete Custom Car Wiring Harness $500
Custom Wet Sump Pans $400 - $600
Dry Sump Pump and Pan Assembly $1,195
Spare Starters (NEW...not USED) $275 ea.
The first engines are scheduled to be ready for delivery on February 1, 2007. Please contact us at 623-581-3222 or e-mail to matt@phoenixracecars.com for more information or to place your order. More information will be available on our website soon.
Matt Conrad
