I'm looking for suggestions for what type of metal I should get for my new rear subframe.
By "subframe", I mean the part that will have mounts for the rear suspension, differential and rear wing.
I'd like to use square tubing, since it's easier to work with.
I'm planning to build my new subframe as mostly bolt-on, using the five sturdy attachments at the back of my RF94 frame. Therefore, for the most part I will be building a stand alone frame, as opposed to welding it to the current chassis' main bulkhead tubes. I do expect to do some welding onto the existing chassis, probably when I start working on the engine braces.
I mention the welding-to-existing-frame aspect because I think it might make a difference if I need to be compatible with Van Diemen's materials.
