I'm in the planning process of making some suspension spares for my 97 Swift (UK) FF1600. The suspension is all aero tube, 1.349x.571x.049", except the pushrods/toe links. I'm considereing making these aero tube as well, but am concerned about strength required on the pushrods, and the slightly less adjustability if using aero-tube versus round tube.
Have noticed in the past that some cars have a few plug/rosette welds along the surface of the aero-tube pushrods, leading me to believe that there is a round tube inside of the aero tube providing additional strength. Can anybody shed any light on this? Is a slightly larger aero tube required for the pushrods? Current pushrods are a set of 7/8" OD w/ .065" wall, and a spare that is 3/4" (wall unknown).
The toe links are 5/8" OD currently, and obviously are infinitely adjustable thru the required range. If I use aero-tube, I'm restricted to a minimum adjustment of 1/2 thread (ie. .021" per 1/2 turn of 5/16-24 rod end). Is this sufficient, or do I need to build in a LH/RH bushing at one end to improve range of adjustability?
Current suspension doesn't have anti-intrusion bars, I'm planning on doing the upper front wishbones only w/ 5/8" OD x .050" wall on the outside w/ 1/2" OD x .062 wall inside. Thoughts?
Any comments or shared experiences would be appreciated, building jigs and ordering tube soon.
Francis Kennette
Belle River, ON
