Page 1 of 2 12 LastLast
Results 1 to 40 of 70
    San Diego, Ca
    Default Stohr F1000 pics
    Made a quick mention late last year on the formula S forum about this car I planned for F1000 conversion. Power is RC51 (a bit lower HP than current I4s) injected V-twin.
    Rear transaxle will be similar to my VanDiemen R1 conversion with the exception of the pushrod and shock location. Engine is stressed in addition to a stressed bellypan that will tie into the front of the transaxle/rear of motor.
    Glad to hear the rules are leaning owards a SIR and 1000lb weight. Will make this car a bit more competive with current I4s.
    BTW, the Vandiemen weighed 725lbs. Hope to have this one around 800.
    Neil
    That's cool, Neil. Looks like high quality fabrication.
    Hey, I could be mistaken, but I think the SIR was dropped from the F1000 rules. I have mixed feelings about the SIR. Lots of pros and cons. I guess the rules makers/deciders thought the cons outweighed the pros.
    Virginia
    Liked: 16
    Default Stohr photos
    Photos of our new F1000 will be coming soon !
    SIR was deleted from the rules. Competitve stock bike engines should make about 170hp at the chain.
    PORTLAND
    Default hp
    With the right pipe and tuning they will make 170hp at the wheels.
    San Diego, Ca
    Default Recent Stohr Pic
    Here's the latest pic prior to boxing in mock transaxle.
    BTW, not worried about being down on power. Not many cars will be showing up next Spring. When fields get bigger in 2008 I'll put in the latest.
    Neil
    Atlanta, Ga
    Neil- looks really good. Quick question... if you are planning to run a R1/ GSXR, etc in the future won't your chassis be too skinny? I think your v-twin will be down on hp but up on turque + will have aero advantages. Might be the smartest choice....
    RC51 is an awesome bike.
    Hasty (or someone) pointed out in a Sports Racer thread that a 98-99 R1 has won the runoffs last 4 or so years running so the "latest/ greatest" is only a piece of the puzzle.
    How (where) are you mounting your rear a-arms?
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    2004 Mygale SJ04 Zetec
    San Diego, Ca
    Default Stohr pics
    Thanks Sean,
    The rear triangles are bolted to the firewall so making up new ones to accomodate any motor is pretty quick.
    A-arms will be mounted off the sides of the mock transaxle.
    Just like my VanDiemen, I'm starting out with just a spool.
    Neil
    San Diego, Ca
    Default Couple New Pics
    A bit of progress.
    Neil
    Virginia
    Liked: 16
    Default F1000
    Very nice ! I haven't seen the old FF2000 for awhile.
    NC
    That is sweet. I ride an RC51, it is a great motor, but you will be down on power and torque. Especially on power!!!! You will never get much more than 130 hp and about 76-78ft lbs of torque. The reason this motor worked on a bike, is that at the time it was competing against 750 cc I4's and the powerband of the twin was so progressive. On a car however. I think that the all out power of the I4's will be a serious advantage. Just my two cents! Beautifull work though.
    San Diego, Ca
    Default Down on power
    No doubt I'll be down on power but I'm building this car to be a bit unique. It will still be fast but I know I won't be running at the runnoffs anyway.
    The next car might be a tripple, just wait and see....
    Neil
    NC
    Are you going to go with a Triumph motor?
    Matthew
    Quote Originally Posted by neildrake
    Neil
    Mark Beckman
    Guest
    Maybe you could apply to run a weight of say 900lbs for twins, open the class up for Yours, Suzuki, KTM, Aprillia and Dukes. (hmmmm 999).
    When I started my spec car I applied to KTM to supply, unlike you I was going to mount it transversly, chain to a CV jackshaft and then to a small car diff.
    San Diego, Ca
    Default Another Pic
    Plumbing Done
    San Diego, Ca
    Default A bit more work done
    A bit more done thanks to Roland Johnson here in San Diego with some of the sheet metal work.
    San Diego, Ca
    Default Exhausting work is finally done
    ...and it runs too. Always a relief.
    Anyone who hasn't heard a late model Jap twin run with a race pipe...music
    Something interesting; the throttle bodies are 62mm! A beer can will almost slip inside.
    Looks great, Neil.
    I wish you weren't on the wrong coast. I'd like to see (and hear) this car run.
    panama city florida
    Default definition please
    hey guys, what is an SIR? you all mention it in the first post as it applies to the F1000 class. Thanks
    [SIGPIC][/SIGPIC]William Pelton
    Senior Member sidney's Avatar
    Ames, IA
    Default Single Inlet Restrictor
    It is an orifice in the inlet that restrics the power that the engine can develop. These are currently not required for the class, but based on reports of Sean O. taking entire straights to get passed by Atlantics, they may be back in before we know it.
    Ian MacLeod
    "Happy Hour: 5:00 - 5:30"
    Tatuus F1k
    panama city florida
    Default thanks
    Since it referrences a "single" air restrictor does this restrictor define the area of the opening that feeds air to the induction system on the motor? Or, is this a restrictor plate that attaches to the motor ala nascar? Also why can't we have an F1000 outrunning a DSR car? I remember Seans report from Sebring, could you clarify? thanks
    Atlanta, Ga
    The Atlantics had no troubles with me... have a look at the lap times!
    The sir would be at the air intake, not bolted to the engine or throttle bodies and no. lets not start talking about that again!
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    Marietta,Ga.
    Liked: 61
    Quote Originally Posted by willpelton View Post
    No way a F1000 will ever out run a DSR, since the DSR's are allowed engine performance mods.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    San Diego, Ca
    Default A couple new pics
    A couple new pics
  24. #24
    San Diego, Ca
    Default finally on the ground
    Takes a lot of time to get from an FC to F1000 but finally this thing is on the ground
  25. #25
    Wow...super-sano looking installation, Neil...congrats!
    I always liked those grunty twins. The best bike I ever had was my RC-51. What a rush...and I'll bet your car gives the same thrill!
    Stan
    Congratulations, Neil.
    As Mike Devins would say, you're 80% done and only have 80% left to do. :-).
    I'm envious. I'm stuck at my floor pan step, waiting for rivets to arrive. Once they show up, I'll only have 80% left to do.
    Neil, do you have your own car building thread? If not, you should. I'm always a little surprised to see your car in this thread. It doesn't look like the Stohr at all!
    San Diego, Ca
    Default It is a Stohr though
    ....but it is a Stohr.
    One of 2 FF2000 that Lee made.
    Maybe Lee could chime in with a small history lesson.
    Neil
  28. #28
    Default Aha!
    Oh, I see. Duh. I didn't realize it was a Stohr conversion. Cool.
    Member Steve Herrod's Avatar
    Owasso, Oklahoma
    Default RC51 HRC parts
    When you get ready to pump up that RC mill a bit, the Honda Engine Kit, Part No. 06100-NL6-020 is only $31,968.72.
    And you thought this was gonna be inexpensive.
  30. #30
    San Diego, Ca
    Default $31K motor
    I'm sure my sponsor will pick one up for me.
    Any idea on what a full race spec v-twin from Honda puts out for power?
  31. #31
    Ann Arbor, MI
    The World Superbike HRC motor was supposed to be putting out 180 - 190HP when Colin Edwards won the WSB championship - same motor Joey Dunlop used at the TT for his last win.
    HRC will not sell them.
    Nice looking car - like the idea of being different.
    There is a Jedi Hillclimb car in Australia with a Ducati 996 motor in it.
    David
  32. #32
    San Diego, Ca
    Default Couple New pics
    Shifter installed.
    Double shear mounts installed.
    Sabelts courtesy of Roland Johnson here in Sandiego; surprisingly light belts if you're that weight conscious.
    Is the chain guard rule for F1000 the same as DSR? 1/4" aluminum or 1/8" steel? Is there a minumum width in addition to thickness?
    Neil
  33. #33
    Atlanta, Ga
    There is no chain guard rule that I am aware of in F1000. It is a good idea as that sucker can cause some damage....
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
  34. #34
    Ames, IA
    Default Who makes the dash?
    That's a sexy little dash display unit. If you don't mind sharing, who makes it?
    Ian MacLeod
    Tatuus F1k
  35. #35
    San Diego, Ca
    Default Dash
    That's the stock Honda dash from the RC51
  36. #36
    Maryland, US
    Liked: 77
    Not true, Sean.
    9.3.39. SCATTERSHIELDS/CHAIN GUARDS
    The installation of scattershields or explosion-proof bell housings shall be required on all cars (except Showroom Stock, Spec Miata, Touring and Improved Touring) where the failure of the clutch or flywheel could create a hazard to the driver. Chain drive cars shall be fitted with a protective case/shield to retain the chain in case of failure.
    Minimum material specifications are:
    .125 inch SAE 4130 alloy steel
    .250 inch mild steel plate
    .250 inch aluminum alloy
    NHRA or SFI approved flexible shields
    Dave
  37. #37
    Atlanta, Ga
    Thanks Dave.
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
  38. #38
    Senior Member Lincspeed's Avatar
    S. E. Michigan, US
    Default Bodywork?
    Neil - beautiful work. I'm just wondering if you will be using most of the stock bodywork - with some extra "bulges" to the engine cowl...?
    Clark Lincoln
  39. #39
    San Diego, Ca
    Default Bodywork
    Hi Clark,
    I will be using most of the bodywork however I don't know if I will be keeping the engine cover yet. The car looked fairly goofy with the tail on and I'll either cut a hole for the air box or just not run the tail at all.
    Interest in doing some artist's rending for me?
    Neil
  40. #40
    S. E. Michigan, US
    Default F1000 Renderings
    Neil - you bet, just get in line...
    Contactme - lincspeed(at)hotmail.com
    Clark
