Changing gears on MK 9 for 88' reynard, put gears in and when I tighten nut on top the axels and wheels turned, what did I di wrong?
Removed and positioned again and same thing happened, very frustrating, also on 4th gear does the gear go in with tabs toward front or back? i.e., the drawing in hewland manual shows then facing in toward engine.
Is the car locked in gear? Fix? I know have someone who knows what they are doing do it.
put car in gear top and reversae to take nuts off shafts, do I leave it that way when I take gears out or put back in neutral? That may be my problem, manual says to take out of gear, prep car formula tape I believe leaves them in gear until change is complete.
Thanks ahead of time!
