Results 1 to 5 of 5
    Fremont California
    Default could be an f1000?
    Check out Ebay Item #110020857187. It could be the basis for an F1000 car? (it's NOT mine!)
    Contributing Member Shep's Avatar
    Rochester, NY
    Would've been much easier if you could start with most of the pieces...
    http://www.apexspeed.com/forums/show...eferrerid=1599
    Redford,Michigan
    Default A works ff chassis
    If Frank still has it,this is a pretty trick car for a home built and could be converted to F-1000.We did the body for it,radiator behind driver,big naca ducts on the sides,uses Reynard uprights on all corners,rocker arm suspension.
    Dave Craddock
    Rochester, NY
    Sorry Dave,
    I meant to be more clear. I believe the two cars - the eBay offering and the AWorks car to be one and the same. It was tempting as a package here on ApexSpeed. Less so as a standalone chassis...
    Liked: 123
    Default How sad...
    How sad when that guy aprts out a car, I've noticed a few that he has done. On the other hand, one of us could have bought the project, I suppose.
