Results 1 to 10 of 10
    Fremont, NH
    Default Nadella Bearings
    I need the Nadella bearings that go inside the rockers on the Ralt RT-41. Anyone have a clue as to where I might find them?
    Pegasus has some of these, but not the right size.
    NH
    Paul,
    Have you checked Mc Mastercarr for them ?
    Fremont, NH
    Yes. I didn't see them unless they're under some strange category.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    What size are you looking for?
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Fremont, NH
    The combined bearing has stamped on it - Nadella RAX 730. It has an ID of 30 mm, and an outside (the needle bearing cup) of about 38 mm. It's hard to measure while in the rocker.
    The second thrust bearing is AX3047, ID=30 mm, OD=47mm, 2mm thick.
    The thrust washer has ID=30mm, OD=47mm, 0.8mm thick, number CP3047.
    Massachusetts
    Quote Originally Posted by Paul LeCain
    Contact Kelly at Shuster Corp. for Nadella Bearings. kdawicki@shustercorp.com
    we stock a large quantity of all types of nadella bearings. thanks, kelly
    Senior Member Rondo's Avatar
    Delaware
    Liked: 22
    Default Updated Nadella Bearing Contact?
    Anyone have updated contact info at Shuster - have tried this contact but with no response
    Santa Cruz, CA
    Liked: 23
    Have you tried Mesa Bearing in Huntington Beach? The supply quite a bit of the motorsports industry with bearings.
    http://www.mesabearing.com/
    They don't seem to be a Nadella rep, but likely other lines have combination bearings available.
    Tim
    'Stay Hungry'
    JK 1964-1996 #25
    Fremont, NH
    Default Shuster
    This is the last contact info I have:
    Shuster Corporation
    4 Wright Street
    New Bedford, MA 02741-3086
    Phone 508-999-3261 ext 522
    Oregon
    Default RT/41 Rockers
    Paul,
    I have them .
    Shoot me a email.
    Mike D.
