Since the topic of the week seems to be suspensions, figured I'd post this now.
I'm thinking of replacing the rear rockers on my RF-85- 1600 FF. From the factory, the outbound side the rockers have fixed attachment point that allows the rocker to be attached to the upright.
I guess at some point the rockers were broken and someone modified them. They have cut off the fixed ends, welded in a threaded rod to which a beefy rod end with Jam nut is inserted.
The rod end is then used to attach the rocker to the upright. To change camber, we simply pull the bolt that goes thru the ears on the upright and the rod-end and spin the end. This allows us to change camber without effecting toe. Elegant simplicity.
Does anyone know of anyone who can make a similiar modification to the new Rockers? I'll post pictures here later so people can better visualize what I am talking about.
