Thread: Water Swirl Pot
    Senior Member LolaT440's Avatar
    CT
    Default Water Swirl Pot
    Can the water swirl pot inlet be above the head/thermostat port?
    If I put my oil tank where it now needs to go, the swirl pot does not fit unless I move it up high. If I move it to the rear of the engine, I'll need to chop up some body work.
    Senior Member Tom Sprecher's Avatar
    Living race car free
    Default Yes
    I think it should be located at the highest point in the system in order to help the system self purge.
    Tom Sprecher
    ATL Region Treasurer
    Mine is higher than the top of the valve cover.
    Hull Bottom, St.Thomas
    It needs to be above the water level of the head.
