Fellas;
I have installed my Ivey 2L into the chassis, but need to ensure the AP clutch is mounted correctly. There is a "0" stamped into the AP housing, and fits adjacent to what I surmise is the "0" degree on the flywheel.
On the flywheel, there are two white marks that appear to be 180 degrees apart. Immediately adjacent and left of one mark, (at approximately 38ish degrees) are two more marks, one yellow and one red. Assuming the flywheel rotates CCW (as does the 1.6L), this would mean that the white mark adjacent to the colored marks is "0" degrees TDC. This logically corresponds to the "0" on the clutch. Does that sound about right? I need to get the back end buttoned up tomorrow. Any help?
Iverson
