Results 1 to 2 of 2
    Member DUNCAN's Avatar
    Indianapolis
    Default Pointless Distributor Question
    I purchased a 78 Fiesta block last year and used some parts off of it to finish my original motor. The Fiesta block has a pointless distributor with the vacuum advance part of the casting. It has a tall blue cap.
    I assume I can use it since there are no restrictions on distributors. But, Is it a wise decision?
    Is there an advantage over points? Does anyone else use one of these?
    Brian Duncan<br />Indy Region
    Senior Member JHaydon's Avatar
    Saukville, WI USA
    I think that distributor would require the use of the "Duraspark" ignition box. I don't know the box very well, but I think it does determine the timing, which would make it illegal for FF.
