I have read the Penske Manual and could not find a reference to the proper technique for checking the nitrogen pressure. It mentions setting the shocks to 200 psi after reassembly and checking the shock pressure as part of a pre race maintenance program. My gauge documents states the shock pressure should be checked with no load on the wheels ie. car jacked up. But I have seen a lot a competitors check the pressure with the wheels on the ground (shocks loaded). It would seem that if the shock is compressed, the volume of the reservoir is greatly reduced resulting in a much higher pressure reading, you know, the old PV=nRT thingy.
Anybody know the correct way to check the pressure. Should we take the shocks out of the car and check them in the fully extended condition?
thanks
dave jalen
