Results 1 to 2 of 2
Thread: Cosworth Blocks
    Santa Ana, CA
    Post
    Iron BDD New Fully Race Prepared 81mm Bore No Sleeves
    "SouthAfrican" " AX " $2000
    Aluminum Replacement Blocks for Cosworth BD Series . 81mm to 90mm Bores and BDH to BDP deck Height Call 714-547-3717 Some used and/or odd experimental stuff available
    Santa Ana, CA
    Post
    Spring Clearance Sale:
    1 Slightly out of spec (new) 85mm bore X 7.25" deck ht. nikasil wet liner block. Matching crank to make 1600cc (1 new , 1 used). 4 reconditioned rods available. Rod and piston "job" numbers included,if required.
    1 off 3 1/2" bore X 7.25" deck ht. (new)alum block with iron liners. Crank available (new) to make 1600cc. Rod and piston "job" numbers available if needed.
    These parts must be sold. All or part. No reasonable offer refused.
