I need a replacement block that does not have the rear ears "trimmed." I have found new blocks that are seven rib design with R-DOT stampings. Is this what I need? Anyone have a good used block?
Sorry Jon! I went out and looked, but can't see enough of the blcok to answer your question.
Stan, Thanks for the attempt.
If you want, you can phone our chief mechanic Adam at our shop in Florida at 407.886.0043... We are a bit confused why you woud want the ears still on these engines if it's for the racecar?
We also have engine parts (crank / pistons) that came out of one of our re-built engines after only 75 miles on them, that we would sell... This was from an engine we converted between engine builders for the pro series... And we likely will have a lot more good usable stuff coming from more conversions soon... yikes !
<a href="http://www.jensenmotorsport.com" target="_blank">www.jensenmotorsport.com</a>
