Thread: Wheel Spacers
    NJ
    Post
    Fellas;
    I just bought Jongbloeds for my drys and have my rains mounted on Revolutions. The Jongbloeds require at least 1/2" longer lugs, making it necessary to use a spacer for mounting the rains. Any ideas?
    NILES,IL. USA
    Post
    I do not understand your problem. Why do you need wheel spacers? Did you have to install longer studs? Are you using open ended or closed lug nuts?
    NJ
    Post
    Sorry for not explaining more thoroughly. There is a uniqueness to the Revolution flanged lug nuts where they screw to within a fraction of an inch to the hub, as well a being solid and in an absence of an opening at the opposite end. But I have since determined the most expedient method is to install longer lugs to accommodate both wheels and to machine a hole at the opposite end of the lugs. Thanks anyway.
