Weird Erratic Idle - Dual DCOE Webers
I'm stumped. Before tearing into them, thought maybe some ApexSpeed Weber guru can help.
Dual DCOE 40 Weber set (on a 1600 for pushrod). When cold or even warming up in the pits before going out, idle is "normal, i.e. can be adjusted fine for 600-800 or so rpm. Even as it gets up to temp (before going out) idle is fine.
But after coming in after a race session idle way too high, maybe 2000+. We just shut of off rather than readjusting. Then after it sits waiting for next session (probably 90 minutes or so), idle will return to "normal" even if pre-warming it up before going out.
Quick inspection doesn't seem to be a return spring(s) problem That is, the linkage and springs return solidly to the idle screw.
I'd sure think it was linkage related but at this point it doesn't seem to be the case and wondering if anyone has seen something similar caused by something other than linkage.
Poor idle, flames & popping thru carbs?
I have just fitted DCOE 45's/36mm to my Ford 2.0L S2 engine and I can't seem to get it to idle correctly... Here is a list of some of the things it is doing: (btw, engine was running well with the 2 barrel weber prior to assembling the DCOE's)
Doesn't idle well (won't idle down)
randomly spitting/popping back thru the carbs
Popping and flames from header on accel and de-cel
random popping in exhaust at idle
Here is a list of some of the basics:
According to documents I have read all the jettings in these carbs should be a good staring point. (possible leaner idle jet?)
Air Correction Jet: 155
Emulsion Tube: F16
Main Jet: 145
Idle Jet: 55F8
Starter Air Jet: 150
Ignition timing 36 degrees at 4000 rpm
Standard S2 cam
Stock mechanical pump (checked/regulated from 2-5psi)
I have tried a number of different things, checking, replacing, cleaning etc but with no success...
I'm starting to wonder about the plastic floats? I seem to remember in other carbs I have run that brass are preferred; less susceptible to vibration? Following one of the other threads on float adjustment I can't seem to get the proper reading at the specified float heights as well as trying different heights... I'm thinking that the level may be to high and it is bleeding over thru the air passage?
I know there is lot more that I could add here, but hoping this is a good starting point. Any help or suggestions would be appreciated.
Regards,
Vince
