8 Attachment(s)
2008 Red Devil Formula 500 and Spares
2015 ground up rebuild.
Powdercoat frame.
6 races since rebuild
2008Red Devil Formula 500 with 494 RAV engine with spare parts and equipment. Fresh rebuild
Engine:
- 1 complete regular 494 Rotax engine 1 race weekend.
- 1 Carb rebuild kit
- 2 Spare magnetos (new)
- 2 Spare ignition units ECU (new)
- 1Spare fuel pump (new)
- 2 Used ignition systems (good condition)
- 1 spare exhaust pipe (used)
Clutch and drive train:
- 1 Arctic Cat drive clutch
- 2 Driven clutch sprockets
- 3 Spare gear (drive) set
- 3 Spare clutch springs
- 1 Spare final drive belt
- 2 Spare primary drive belts
- 1 spare mount for secondary clutch pulley bearing
Suspension parts:
- 2 New rear hubs
- 1 Spare steering arm (fits either side)
- 1 Spare set front shock struts with rod ends
- 1 Spare set tie rods with rod ends
- 1 Set (4) digital scales (365 lb. capacity each, so that wheel weights fall into most accurate range of scales)
- 2 Rear bearing brackets (new)
- Front and rear bearings
Brake Parts:
- 1 Spare front caliper mount (fits either side, new)[/SIZE]
- 1 Brake Bleeder system
- 2 sets brake pads (like new)
- 1 Spare rear caliper
- 1 Qt. Red Line high Temp Brake Fluid
Fire System:
- 1 Recharge kit
- Miscellaneous fire extinguisher system fittings and replacement parts
Tools and Setup Equipment:
- 1 Set (4) digital scales, 365lb. capacity each, so wheel weights fall into most accurate range of scales
- 1 digital level for caster/camber
- 1 set (4) bolt on plates to place wheels for more accurate chassis setup (aluminum)
- 1 Laser project wheel tracking
- 1 Toe in bar for use with dial indicator for accurate toe setting (dial indicator included)
- 1 Longacre tire pyrometer (digital)
- 1 tire gauge
- Spare weights
Miscellaneous Parts and equipment:
- 1 Compression Gauge
- 1 Spare water overflow system
- MyChron 4 dash system with GPS and computer download access
- Bolts and nuts to replace any bolts on car
- Wiring parts to fix any wiring on car
- Wheels and tires for trailering (4)
- 3 Sets racing wheels
- 1 New set rain tires (mounted)
- 1 My Laps transponder
- 1 Car lift (Electric)
- 1 Quicklift jack
Price: Car and Spares - $10,500 (Car Only - $9,000)
Contact: Robert Selck (608) 290-9412 or rwselck@yahoo.com
