How to remove decal adhesive?
I am trying to remove old decals from a trailer. I used slight heat from a heat gun to peel them off, but adhesive residue was left behind. I tried Goo Gone and it did not work. I am concerened that anything else that would do the trick would also remove teh paint.
I may try WD40. Has anybody had any luck with anything else?
When peeling off any sticker, do not pull it off on the dirction you're removing the decal...but lift the decal and pull it the opposite way, usually this way 99% of the glue stays with the vinyl....for the 1% I use a rubbing alcohol and my fingers to soften the very sticky glue then scrape it off with somthing like a credit card or the Sticker spatula.
Just make sure U do this in the shade and wash off any residue with car was type of soap...
