Titan MK6C Chassis CSR/DSR Race Prep
Titan MK6C Chassis CSR/DSR Race Prep R1 Motor w/Body Molds. New Paint. Titan MK6c chassis with a carbuerated 2001 Yamaha R-1 powerplant. Total car weight less driver is 930#. This chassis is a Formula Ford conversion that has been strengthened and stiffened. This car is fully Homologated for CSR/DSR with S.C.C.A. I have ALL the log books from original to current era. This car is very easy to drive and is spacious enough for a larger driver. This is a reliable fun car to drive...alot of bang for your buck. Alignments done by LMI prep shop as well as chassis strengthening. The body is three piece fiberglass with the full set of molds included. I am offering with the car an extensive spares package...everything goes with the car... spares, some tooling and all documentation.
2001 Stock Yamaha R-1 in car ( Pressurized airbox with K&N air filter, Graves jet kit installed in carbs, Mark's Performance Stainless header 4 to 2 to 1, Barnett SR-3 clutch kit, carbon discs, CNC machined oil pan baffle,Mobile 1 MX4T oil, oil and filter changed every weekend. )
Beasley Spool unit with updated heavy duty axle.
AIM Mychron Gold Kart dash. ( RPM, oil temp, water temp, speed, lap times, gear position and track mapping )
Onboard fire system.
3 sets of Kodiak wheels.
1 set of Minilite wheels. ( with brand new mounted Hoosier rain tires )
1 set of wheels. ( 2 Minilite fronts & 2 Revolution rears )
2 Formula Ford steel wheels. ( powder coated white )
1 set of brand new Hoosier slicks.
AMB Transponder
Carrera shocks.
'86 Ralt Atlantic wing.
2nd Back-up motor ~1999 Stock Yamaha R-1 complete car kit. ( coils, wires, ECU, rectifyer, fuse block, starter, Barnett clutch kit, carbon discs, oil filter adapter, Loynings oil pan baffle, Graves jet kit installed in carbs and airbox. )
3rd Back-up motor ~ 2001 stock Yamaha R-1 bare motor.
2001 R1 Loyning Race Prep Motor (Extra Fresh)
Pennon carbon fiber wing with carbon/honeycomb end plates.
front sprockets 15T and 16T, rear sprockets 44T,45T, 48T and 49T. ( split sprockets...easy to install. )
3 spare noses. ( all three need various repairs, but fixable. )
complete body and undertray molds. ( nose, center and tail. )
lots of engine gaskets, sealants, hardware and parts.
springs, A-arms, trailing links, uprights, brake rotors, etc...
lots and lots of misc. spares from throttle cables to hardware
I am offering this TURNKEY DSR package at an affordable price of $18,200 for EVERYTHING!!!:checkered:
Dan
DSowinski@mcdsi.com
312-339-3939
