1 Attachment(s)
Kent 1600 oil pump identity
I have a Kent Crossflow 1600 with a side mount oil pump. The port routing and configuration are different than the current Pegasus Racing 167-01-side pump, but body shape is the same. I am restoring the car and am in the process of re-figuring engine oil line/filter/cooler layout. Should I "wing it" with the current pump and hope the previous layout is correct (system is carrying 80 psi plus) and just update hoses/mounts and correct pressure ? Or purchase a "known quantity" and follow a current/ supportable layout ??? The engine has no documentation, but block is painted gold, any ideas of builder ? Secondly, the pump is stamped with a large "P" on the face plate... Any ideas ??? Thanks for the help
You may be on to something...
When talking about this pump, I think a 4 port w/gauge port would be more correct. When explaining the layout to Pegasus, I let them know the "upper right" face port ( not seen in the photo) was a gauge port. The pump, as set-up, has two inputs left and two outputs right (one to the front of block, the other to filter/cooler/tank) with the gauge port independent of the other "work ports". The fellow at Pegasus did think it a period correct pump, and the "P" could be for Ed Pink racing engines since he was trying his hand at FF in the early 70's.
The psi is cold/cool at idle is 45 and over 3,500 rpm >80. Will dial back the pressure as get more info on the pump. Haven't run engine in to much, but very strong, no chatter and no smoke. Is a 711M6015BA block w/canted plugs in head.
Someone knew what they were doing when this thing was originally assembled...
