A few questions.
Radiator[s] How big? Brand or manufacture. Fuel plumbing. I seem to remember a diagram [Chris Ross ?] on here somewhere. Can't find it. MC sizes for front and rear and why?
Will
A few questions.
Will
One big radiator in one sidepod and one BIG oil cooler in the other sidepod. Oil temperature and pressure are critical for the crank bearings at 15,000 rpm. Go to our main forum at - www.formula500.org/forum.php and find a nearby F600 driver so that you can see his car up close. Read everything that you find here and there. Crew for a
F600 driver for hands-on learning BEFORE you spend any money.
Will the old trick of using a GM Air Conditioning condenser work as radiator and oil cooler on these cars? I know that in the past we have used those as oil coolers on some pretty "heavy duty" V-8 race stuff (pre heat exchanger days). It seems like you could use one for water and one for oil and you would never be at risk.
If you don't get an answer here, go to our main forum - link shown in above post.
No. Drop down or serpentine style AC condenser will struggle to be woefully inadequate.
The space available in the sidepods or ? is quite limited as well.
There seems to be no "cheap" way to cool these engines, keeping in mind that these engines are run much, much harder than in any motorcycle application, so temps are naturally going to be more, and need serious cooling.
Regards, GC
Do a search on ebay for aluminum racing radiator. You will find many low cost solutions.
