1985 Swift DB1 085-55
Straight, clean, and well-maintained. Car has only run Solo events since full frame up rebuild in 2007. AiM dash indicating 1336 miles (~80 miles/year) since frame up. 875 lbs dry. Highlights:
~ Fresh Ivey in 2020 featuring new Ford Motorsports block, new Ivey aluminum head, Ivey forged pistons and SCAT crank with less than 4 hours runtime. Billet aluminum valve cover. Pertronix Ignitor. MSD Soft-Touch Rev-Limiter. Hy-Tech exhaust with muffler (to~90db) and extra straight pipe.
~ Mk9 rebuild by Taylor Race Engineering in 2007. New 9:31 R&P by Averill in 2012.
~ Anze refresh in 2019 of SRP Fox Racing shocks with Penske internals. ICP/HyperCo spring perches and Torrington bearings. Comprent sway bar adjuster.
~ 2010 Fast Forward upright rebuild with new bearings (DB6 rears), hubs, and stub axels. Fast Forward drive pins. Porter floating rotors with aluminum hats. AP Racing aluminum LD19 calipers. Fast Forward wheel cone/nuts. New CV joints in 2023.
~ Full frame up in 2007. Frame blasted and powered coated. New bonded riveted floor pan / bulkheads. New Fast Forward Full width front skid plate. Aero-Tech refurbished fuel cell. New aluminum radiator. Averill steering rack rebuild. Fast Forward steering clevises. All new AN hardware. New wiring, buttons, and switches. New AiM MyChron3 Plus. New Spa quick-release. New Momo steering wheel. All new Pennon bodywork in while gel-coat. New Fast Forward body guide pins. New K&N air filter. New Girling Master Cylinders with billet caps.
~ 12 Panasport Ultra-Light-Weight center lock wheels. 4 with R20 tires (14 runs). 4 with R20/R25 tires (17 runs). 4 with Rains (0 runs). 6 Centerline center lock wheels with 4 cones/nuts. 2 new R20 rears.
~ Chassis specific hardware spares, OEM seat. Brass Radiator. “Waterford” mild steel header with SuperTrapp. Numerous springs, sway bars, rockers, a-arms, track rods, etc. Flag alignment system.
~ 2013 CM championship as well as numerous CM National, Match, and Tour trophies.
Car located in Midland, MI. Delivery negotiable.
23-1211: OFF MARKET
https://www.apexspeed.com/forums/att...d=108368&stc=1
