Need Brabham BT21C photos
I am trying to locate parts to restore my BT21C to FB specs. The previous owner had converted the car to FF specs. The rear suspension seems good but the front has been significantly changed. The front now has smaller rotors, steel Girlings and a steel Triumph hub.
I am looking for photos of a correct BT21C front suspension showing the hub, wheel studs, rotor and brake caliper. A photo of the mounting side of a front wheel would be great also.
I do have the original MRD brake caliper brackets so that is good. I think I have located a pair of correct rotors at GMT and J.R. Mitchell thinks he can help with the rest but any other sources would be great to know about.
Does anyone know what the correct Girling front calipers should be?
