7 Attachment(s)
Carbir FB for Sale - Sold
For sale: Carbir formula B car SOLD
Converted FC Carbir Formula B, Conversion done by Kevin Mitz completed in around 2015. Car was run once and finished every session of the weekend. I have moved on to a P2 and this car needs to go.
2009-12 GSXR 1000 motor George Dean sorted the oiling system, dry sump, drilled crank, external oil feed for the crank. There is a bit of an oil leak in the oil pan other than that the motor is pretty well sorted. Uses stock pick-points for the rear suspension and stock Carbir/Piper DS-3 geometry.
Asking 17.9k
John (408) 356 two eight four three or Racerh@msn.com
- Exhaust is a custom 4 into 2 into 1 stainless system by Kevin Mitz
- Exterior fuel fill, so you don’t have the take the car to pieces and risk filling the car with gas when you fuel up.
- Includes MXL Pista Dash,
- Belts good to 2023
- Pedal mounts from a piper so you can unbolt the mount and move the whole unit forward
- Full plumbed in Fuel injection system, in tank pump, pressure sensor to the Pista
- Has SCCA logbook as an FC and ICSCC logbook as FBX.
Extensive spares including:
- 2 Core motors (one is missing a clutch basket) the clutch wrench I should have bought is included
- Spare dry sump pan and pump
- Spare injectors
- Spare starters and water pumps
- Engine tools
- Engine: Gasket set, Gear nuts, valve shim set other parts as well.
- Gears front 14, 15, 16 (I think the 17 is in the car)
- Gears Rear 41, 42, qty 3 44, qty 2 45, 47,48 (not sure what is in the car)
- 1 sets xtra wheels (2 total sets), and a set of pit wheels
- Spare nose
- Spare front wing and winglets
- Spare rear wing (upper, lower and end plates)
- Spare radiator
- Spare rear suspension (front is available from Carbir)
- https://www.apexspeed.com/forums/att...id=93040&stc=1https://www.apexspeed.com/forums/att...id=93039&stc=1https://www.apexspeed.com/forums/att...id=93038&stc=1https://www.apexspeed.com/forums/att...id=93034&stc=1https://www.apexspeed.com/forums/att...id=93037&stc=1https://www.apexspeed.com/forums/att...id=93035&stc=1https://www.apexspeed.com/forums/att...id=93036&stc=1
