I finally bit the bullet and sent this letter to the CRB.
Quote:
With the CSR/DSR/S2 merger into P1 and P2, and the proposed merger of F5 and F6, I request you merge FST into FV effective 1 January 2015.
Formula Vee participation has been fairly stable in recent years, but in my opinion FST's growth has been hampered by its lack of national class status. Now FV is considering allowing disc brakes (Yes!), link-pin beam parts are getting hard to find and the one remaining source of 1200cc cylinders and pistons has quit making them. Meanwhile, over in the 1600cc world there are many sources of all parts, and they are less expensive than FV parts.
SCCA now has years of experience watching FST. The class has a mature set of rules. Nearly 100 cars are built or converted. We know how fast they are at every track in the country, and adjusting them pack to the pointy end of FV is a simple matter of reducing their inlet restrictor slightly.
For instance, at Road America the FV race record is 2:41.4, while the FST record is 2:39.1. All that would need to be done is reduce the inlet restrictor from 32mm to 31mm or 31.5mm. Jim Schings at SR Racing could tell you, as he is the guy who developed the FST engine package.
I recommend keeping the FV name. Just divide the FV rules into two sets called (for instance) FV-1200 and FV-1600. The current FV rules would form the first section, with the current FST rules forming the second (with the smaller restrictor). No other changes need to be made to either set of rules.
Thank you and keep up the good work!
