RF-95 Van Diemen Quicksilver
RF-95 Van Diemen - Quicksilver Pinto chassis # 2107
Bought this chassis to restore and use for doing new suspension and aero updates. This car is being reassembled with a lot of new components,as well completely refurbished for a performance upgrade. In the fall of 95 we built and tested a wide track version and the results were super positive. However after a trip to the VD factory we decided to build what was the 96 Monoshock chassis. Have always wanted to re-visit this and have taken it a step further with a w-base extension. Chassis also has updated front and rear wings as well as new diffuser. With the new Pinto Power could be at the front driven correctly.
New "Von Demon" Wide track 4"wider / Long wheelbase suspension 2" longer
Blueprinted gearbox with new alloy diff and CWP geared for Road Atlanta, case and adaptor housing coated in Cerakote
Magnesium uprights rebuilt,new Wilwood LD-20's on drilled rotors,[incredibly light corners 4lbs lighter than modern Van Diemen]
Fresh Penske 8760 triples with updated internals, mechanical front droop limiters
New Alloy Rads
New ABS Floors
New AIM Data logger
New Sparco Wheel and Belts
2 Sets of freshly powdercoated OZ wheels with new wets and drys
ATL Fuel cell with Filters and Pump out kit
All new Summit Plumbing, oil, water, brakes, clutch, fuel
New nosebox in honeycomb with new battery
Refurbished as new steering rack, coated in Cerakote
Can have a choice between Stainless or Alloy floor, 12lbs diff
Bodywork is bare ready for paint can be sprayed any color.
17,500 can deliver anywhere. 727 743 6725
