The title says it all, I'd like new o rings, but don't want to rebuild the pump. Has anyone done this before?
Most likely, these are simple off-the-shelf parts, i.e. not proprietary. A trip to the service counter of your local hydraulic supplies store with your o-rings in hand might provide what you need?
cheers,
BT
I bought an o-ring making kit years ago, and it has been handy to have around. Basically, it is a razor blade, super glue and V blocks to assist good cuts and straight gluing. It came with some o-ring material, but I have also purchased it from McMaster-Carr in the diameters I've needed.
Pace pumps are now made by Neil Brown Engineering - they should be able to advise on o-ring sizes.
Alternatively take measurements off your existing ones. It's worth measuring both the rings themselves and the grooves, then look up or talk to a supplier.
