Originally Posted by
ajpastore
Looking at the Aim sensor, I've never felt confident the probe would stick far enough into the case to reflect oil temp as opposed to the saturated engine case temp. Probably an unfounded concern so don't quote me- but that's why I use the standard sensors we've used for ever, and came up with the curve to use them. They are also much less expensive.
As Greg states, being in a hard fought battle, in the draft will definitely produce higher temps. So you should always try to run out front:)
You can see the difference lap to lap, hotter when following, cooler when in clean air. I've seen the temp drop just by pulling out of the draft down a straight.
-Andy
