Hewland Mk9 reverse “spud”
Rehabbing a Mk9, and the case was not fitted with reverse from new. I have a reverse spud but I don’t think it’s for this gearbox as the locating hole on the spud doesn’t seem to be in the right spot. So I have a few questions before I try to install this one, or shell out for new only to find its same as what I have.
1) can someone take a photo or share some dimensions for a mk9 spud so I can assess whether this is the correct one is for this box? Specifically OD of the body that fits in the case, overall length, and most importantly the location of the cross/locating hole on the body?
2) There is a threaded hole in the case which is where the retaining screw should go, and I think it’s just been fitted with a plug screw from the mfr. to close up the hole. Wanted to confirm that this hole needs to be drilled out to pass the retaining screw when witted with reverse spud? Sealing washer or no?
3) Confirming this is a heat fit to install, and any other general advise on fitting the spud to the case as far as dos and donts?
thx!
chris
