Tiga SC81 Newbie Questions
Hi, I just purchased my first S2000, a Tiga SC81. I know some of the previous owners are on this forum. All my racing experience is with Alfas. So, I've got some learning to do.
Here is my first salvo of basic questions I'm hoping you all can answer:
1. The previous owner said they always used race fuel (i.e. 110 octane). Is that recommended? I would have thought these pinto engines could run on 93.... or even less.
2. I noticed that some, but not all, the rotors are loosely bolted in with aircraft lock nuts. Should those bolts be snug (tight?) or should they be loose so that the rotor can float?
3. Any recommendations on engine oil? I don't have any history on the engine build, but it is supposedly fresh with only break-in oil in it now.
4. I'm assuming I should charge the battery - true? Any issues with just hooking it up to a standard battery charger?
5. Does anyone know the wheel size/offset for these? If not, I'll just measure them. I'd like to get a third set of wheels.
6. Before I start writing one myself, does anyone have a good checklist to use to go over the car before the season?
7. The rear brake cooling duct that is mounted to the rear bodywork is melted - too close to an unwrapped header! Any suggestions on what to replace this with... other than the obvious?
8. I've never driven a Hewland box before. Kindly, Hewland has instructions on their website :). Any suggestions for my first time out?
9. Is there anything out there that resembles a "owners manual" for a Tiga?
Thanks! Hope to be out there in the spring.
bob brady
Unionville, PA
